Vo tas ir tas kas mani arī pie Golf 7 kretinē.. es ņemtu B5 Passat
bet nu tas tā
droši vien nekas neatliks kā mainīt atkal nost.
te no angļu val.
Quicker fix than fsnas
1. Unlock car
2. Unplug negative terminal keeping keys out of the way (so you don’t accidentally press anything) and leave unplugged for 10 seconds or so.
3. Reconnect
4. Lock car
5. Unlock car
6. Insert key to light up dash but don’t start car
7. Remove key
8. Lock car for 10 seconds
9. Unlock car
10. Insert key but don’t power up
11. Unlock park brake with foot on brake – YAY!!!
12. Power up
13. Warning lights may be (anti skid control, tyre pressure, steering etc)
14. A quick drive round the block should correct the above if not into VW for resetting.
