VWmotion.lv • Apskatīt tēmu - Passat B3 1.8 mono zobsiksnas maiņa
Atbildēt Strazds318 » 2008/Jūl/18, 15:28
Vēlējos uzjautāt, vai kādam gadījumā nebūtu pieejama info par metkām Passat 1988 gada (3.modelis) 1.8 motoram ar monošprici?! Jau iepriekš pateicos!
Strazds318
Atbildes: 3
Pievienojies: 2008/Jūl/18, 15:24
Atbildēt Storms » 2008/Jūl/19, 0:22
Solītā instrukcija:
Manufacturer: Volkswagen
Model: Passat 1.8, RP
Year: 1988
Timing belt replacement intervals
The information relating to timing belt replacement intervals is additional to the main purpose of this CD, but is included to provide guidance to garages and for customer advice.
Where possible the recommended intervals have been compiled from vehicle manufacturers’ information. In a few instances no recommendation has been made by the manufacturer and the decision to replace the belt must be made from the evidence of a thorough examination of the condition of the existing belt.
Apart from the visible condition of the belt, which is explained fully later in this section, there are several other factors which must be considered when checking a timing belt:
1. Is the belt an original or a replacement.
2. When was the belt last replaced and was it at the correct mileage.
3. Is the service history of the vehicle known.
4. Has the vehicle been operated under arduous conditions which might warrant a shorter replacement interval.
5. Is the general condition of other components in the camshaft drive, such as the tensioner, pulleys, and other ancillary components driven by the timing belt, typically the water pump, sound enough to ensure that the life of the replacement belt will not be affected.
6. If the condition of the existing belt appears good, can you be satisfied that the belt will not fail before the next check or service is due.
7. If the belt does fail, have you considered the consequences. If the engine is an INTERFERENCE type then considerable expensive damage may well be the result.
8. The cost of replacing a belt as part of a routine service could be as little as 5 to 10% of the repair cost following a belt failure. Make sure your customer is aware of the consequences.
9. If in doubt about the condition of the belt - RENEW it.
Replacement Interval Guide
Volkswagen recommend:
--> 1995: Check & adjust every 20,000 miles (replace if necessary).
1996 --> Check at first 60,000 miles and then every 20,000 miles (replace if necessary).
No manufacturers recommended replacement interval.
The previous use and service history of the vehicle must always be taken into account.
Check For Engine Damage
CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve-to-piston damage in the event of a timing belt failure is MOST LIKELY to occur.
A compression check of all cylinders should be performed before removing the cylinder head.
Special Precautions
• Disconnect battery earth lead.
• DO NOT turn crankshaft or camshaft when timing belt removed.
• Remove spark plugs to ease turning engine.
• Turn engine in normal direction of rotation (unless otherwise stated).
• DO NOT turn engine via camshaft or other sprockets.
• Observe all tightening torques.
Removal
1. Raise and support front of vehicle.
2. Remove:
- Auxiliary drive belt(s).
- Auxiliary drive belt tensioner (if fitted).
- Crankshaft pulley bolts [3].
- Crankshaft pulley [4].
- Water pump pulley (if required).
- Timing belt upper cover [6].
- Timing belt lower cover [5].
3. Temporarily fit crankshaft pulley. Lightly tighten one bolt.
4. Turn crankshaft until timing marks aligned [1] & [2].
5. Ensure distributor rotor arm aligned with mark on distributor body [8].
6. Remove:
- Crankshaft pulley bolt [3].
7. Slacken tensioner bolt [7]. Turn tensioner anti-clockwise away from belt. Lightly tighten bolt.
8. Remove timing belt.
Installation
1. Ensure timing mark on camshaft sprocket aligned [1].
2. Fit timing belt to crankshaft sprocket and auxiliary shaft sprocket.
4. Ensure timing mark on crankshaft pulley aligned with mark on auxiliary shaft sprocket [2].
6. Fit timing belt to camshaft sprocket and tensioner pulley.
7. Ensure timing marks aligned [1] & [2].
8. Turn tensioner clockwise until belt can just be twisted with finger and thumb through 90^ at V.
9. Tighten tensioner bolt to 45 Nm [7].
10. Turn crankshaft two turns clockwise.
11. Ensure timing marks aligned [1] & [2].
12. Ensure distributor rotor arm aligned with mark on distributor body [8].
13. Check belt tension.
14. Install components in reverse order of removal.
15. Tighten crankshaft pulley bolts [3]. Tightening torque: 20-25 Nm.
16. Tighten auxiliary drive belt tensioner bolt to 20-25 Nm (if fitted).
17. Tighten water pump pulley bolts to 20 Nm (if removed).
Storms
Atbildes: 12858
Braucu ar: VW Passat B3
Dzinējs: 2E
Atbildēt Storms » 2008/Jūl/19, 0:41
Aizdedzes secība:
Storms
Atbildes: 12858
Dzinējs: 2E
Atbildēt Strazds318 » 2008/Jūl/19, 11:19
Paldies par izsmeļošo info! :) :worthy: :worthy:
Strazds318
Atbildes: 3
Re: Passat B3 1.8 mono zobsiksnas maiņa
Atbildēt janisu » 2013/Okt/22, 21:03
Ok, rīt mēģināšu, pa vienu dienu ti var reāli izdarīt!?
janisu
Pievienojies: 2013/Okt/22, 20:48
Braucu ar: Passatu
Dzinējs: 1.9 d
Atbildēt iynx » 2013/Okt/23, 0:24
B4 passatam viens pats lēnā garā visu izdariju pa 3h.Saliku pat tik precīzi ka aizdedze nebija jāpāregulē
iynx
Atbildes: 26
Pievienojies: 2009/Okt/29, 1:17
Braucu ar: audi
Dzinējs: 1.6 ADP LPG
Atbildēt ajms » 2013/Okt/23, 12:32
iynx rakstīja:B4 passatam viens pats lēnā garā visu izdariju pa 3h.Saliku pat tik precīzi ka aizdedze nebija jāpāregulē
a salikt precīzāk vnk nav iespējams, var tikkai uzlikt nepareizi par vienu/vairāk zobu +- ;)
Atbildēt zapars » 2014/Jan/07, 17:25
ok, b5 pasātam irkāds pats mēģinājis mainīt?:D
zapars
Pievienojies: 2014/Jan/07, 16:34
Braucu ar: passat
Dzinējs: 1.6
Atbildēt OZons » 2014/Jan/08, 1:41
ir daudzi, tur visa priekša jānolasa nost,un atšķirība ir tajā, ka tur ir automātiskais spriegotājs, vēl daži sīkumi
OZons
Atbildes: 1966
Braucu ar: Passat B6 Corrado
Dzinējs: 1.8 20VT+
Atbildēt Lakkijs » 2014/Jan/08, 10:10
Manam VW Golf 4 arī tas stāv priekšā - detaļas sapirktas, bet nav vēl pašrocīgi darīts :hohol:
Lakkijs
Atbildes: 2906
Atrašanās vieta: Talsi
Braucu ar: VW Bolf Highline
Atbildēt h8499 » 2014/Jan/08, 10:32
Dīzelim siksnas maiņa var ievilkties 200 lašos un vairāk :d
Atbildēt Lakkijs » 2014/Jan/08, 12:23
Man 2.0 benzīns.. tur ap 130ls tas sanāk darbu ieskaitot, ja pats nu tad 100..
Lakkijs
Atbildes: 2906
Atbildēt ajms » 2014/Jan/08, 20:32
zapars rakstīja:ok, b5 pasātam irkāds pats mēģinājis mainīt?:D
ja Tev ir B5 1,6 benzīns(AHL) cik noprotu ,tad
zobsiksnas komplekts SKF(zobsiksna,spriegotājs) - 43eur
ūdenssūknis SKF 45Eur,Graf 35Eur
maiņa 70Eur
ja ir ADP dzinējs ,tad ūdensūknis ir "ārpus" zobsiksnas,var mainīt/nemainīt.Bet praktiski maina,jo tas pie reizes/montāžas izdevīgi. ADP ū/sūknis 25Eur.
Atbildēt ginters333 » 2017/Okt/17, 19:09
B3 1.9 td pasātam 1h laikā var nomainīt
ginters333
Pievienojies: 2017/Okt/07, 2:02
Braucu ar: Pasat b3
Dzinējs: 1.9 TD
Atbildēt mahi01 » 2021/Feb/22, 9:12
Amazon Prime is a subscription service that caters to the media needs of people through the Amazon Prime platform. https://myamazoncomtv.prodssites.com Notifies visitors about topics such as Register TV, Amazon Prime TV and MyTV code. https://amazoncodemytv.prodssites.com To register your device on the Amazon website you go to our website https://amazoncommytv.prodssites.com and enter the given code. https://amazonmytvcom.prodssites.com Amazon Prime Video is one of the best platforms to watch movies and TV shows continuously on the internet. https://amazonmytventercode.prodssites.com You can now watch your favorite shows not only on your laptop or computer but also on your Smart TV and streaming sticks. It is also available on a few selected set-top boxes at a cheaper cost.
