VWmotion.lv • Apskatīt tēmu - DSG eļļas maiņa pašu spēkiem!
Atbildēt Kvatra » 2011/Feb/04, 9:59
Te info par procesu:
Kopā materiālos sanāk 81 Ls (VW centrā pēdējo reizi noplēsa kaut kur ap 160 Ls :) ), t.i. filtrs, blīvgredzens, jauna skrūve ar šaibu un eļļa 6l. Speciālo uzpildes uzparikti var uztaisīt pats vai pildīt caur filtra caurumu no augšas. + vajag VAG COM lai čekotu kārbas eļļas temperatūru.
Special tools, testers and items required:
Vag-Com, VAS 5051
Adapter for oil filling, VAS 6262
Oil collecting tray
Skrūve - N90215404 = 1Ls
Eļļas filtrs - 02E305051B -> 02E305051C = 7Ls
Eļļa 1litrs - G052182A2 = 12Ls
Šaiba skrūvei - N0438092 = 0.20Ls
Blīvgredzens filtram - N91084501 = 0.80Ls
- Engine off - do not start!
- Place oil collecting tray underneath transmission
- Slowly remove filter housing; before removing filter housing from transmission, tip it slightly in its seating.
- This allows oil to flow back into transmission from filter housing
- After you have inserted filter with - shoulder - downward, tighten housing to 15 ft-lbs (20 Nm)
- Raise vehicle
- Remove noise insulation tray
- Remove inspection plug A near pendulum support
- A black plastic overflow tube is located in this hole (with 8 mm hex socket head, torque specification: 26 in-lbs (3 Nm), i.e. about finger-tight).
- Its length determines oil level in transmission
- Remove this oil tube (about 5 liters of oil will drain)
- Reinstall overflow tube, 3 Nm
- Install adapter - A - from VAS 6262 hand-tight in inspection hole
- Shake oil containers before opening fill 5.5 liter DSG oil.
- To change bottles, shut-off valve can be closed or oil filler adapter VAS 6262 can be held higher than transmission
- Move through VAS 5051 until DSG oil temperature is displayed or Vag-Com Select 02 Auto Trans go to Meas.Blocks-08 grup 019 and then GO.
- Now start engine
- Press brake and shift into each selector lever position for approx. 3 seconds. Place lever in position P again
- Do not switch off engine!
- Wait till DSG oil temperature riches between 35 ° to 45 ° Celsius
- Disconnect quick-release coupling of adapter for oil filling VAS 6262 with engine running
- Let excess oil drain
- As soon as the oil has run out (it begins to drip), remove adapter for oil filling VAS 6262 and install bolt with new seal - arrow:
- Tightening torque: 33 ft-lbs (45 Nm)
- Turn off engine
- Dispose of oil in an appropriate manner
- This completes changing oil and filter.
Te vēl linki un bildes:
http://www.mkv-gti.net/wiki/index.php?t ... ission_oil
http://forums.tdiclub.com/showthread.php?t=169356
http://forums.vwvortex.com/showthread.p ... l-Write-Up
http://deviantspeed.com/diy-dsg-fill-tool-vw-vas6262
Kvatra
Atbildes: 55
Pievienojies: 2006/Jūl/13, 15:01
Atrašanās vieta: Cēsis
Braucu ar: Audi Quattro
Re: DSG eļļas maiņa pašu spēkiem!
Atbildēt Kavacky » 2011/Feb/04, 10:08
To eļļu no zelta ražo ar platīna nanodaļiņām?
kavacky.lv
Kavacky
Atbildes: 593
Braucu ar: Golf Mk3
Atbildēt Kvatra » 2011/Feb/04, 10:10
Tā viņa maksā, sālīti sanāk :) neoriģinālo neesmu meklējis, bet nu labāk neriskēt ar ieberzienu uz DSG remontu :mrgreen:
Kvatra
Atbildes: 55
Atbildēt envy » 2011/Feb/04, 10:45
nevienam nav iebildumu jā pārsviedīšu uz dari pats sadaļu?
Atbildēt 16vLietotājs » 2011/Feb/04, 10:55
Papildinu info:
Ella nav obligaati jaalej caur apakshu.
Izlej pa apakshu, aizskruuvee skruuvi un kaarbas augshha pa filtra caurumu leenaam in praatiigi salaej tos 6 litrus, tad uzsildi motoru izej pa visem robiem ieliec [P]arkingaa un ar to pasu apakseejo skruuvi nolej lieko ellu nost.
Princips kaa parastam automaatam.
Un ella ir daarga taapeec ka vinai jaanodrosina klasiskaa automaata hidrobloka darbiiba kombinaacijaa ar parastaas kaarbas zobratu efektiivu ellosanu.
16vLietotājs
Atbildes: 1364
Braucu ar: KTM & HDi
Dzinējs: ir ekonomisks :D
Atbildēt Xplod » 2011/Feb/04, 11:04
jautājums nedaudz ne pa tēmu ,
kur aizņemties 4motion Haldex filtra atslēgu ?? :roll:
Atbildes: 4151
Braucu ar: VW Touran
Dzinējs: 2.0 16V TDI DSG
Atbildēt Kvatra » 2011/Feb/04, 11:09
16vLietotājs rakstīja:Papildinu info:
Tā viņš ir, pa augšu ir vienkāršāk, nav jātaisa tā uzpildes uzprikte. Var pielietot trekteri ar pagarinātu izvadu :)
Kvatra
Atbildes: 55
Atbildēt J.K.jr.bad. » 2011/Feb/05, 14:54
Kaut kad mainīju ģimenes auto eļļu kārbai. Eļļas ieliešanau caur augšu prasa diezgan daudz pacietības un laika. :D Bet nu paveikts tika. Ja kas ir palicis viens eļļas iepakojums. Izrādījās, ka tik daudz nevajag.
J.K.jr.bad.
Atbildes: 1284
Braucu ar: VW Passat Syncro
Atbildēt Kavacky » 2011/Feb/05, 22:48
16vLietotājs rakstīja:Un ella ir daarga taapeec ka vinai jaanodrosina klasiskaa automaata hidrobloka darbiiba kombinaacijaa ar parastaas kaarbas zobratu efektiivu ellosanu.
Tad tā loģika kļūst skaidrāka.
kavacky.lv
Kavacky
Atbildes: 593
Braucu ar: Golf Mk3
