Auto Skoda Octavia II 1.9TDI, šobrīd ~161000km
ir sekojošas kļūdas.
diagnostikas laikā motors bija iedarbināts
Jautājums cik viņas ir kritiskas (cik Ls maksās salabot)
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LB HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9251
Revision: --H07--- Serial number: SKZ7Z0G4603420
Coding: 0050071
Shop #: WSC 73430 790 00000
1 Fault Found:
012295 - Camshaft Position Sensor (G40): No Signal
P3007 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 254
Mileage: 147039 km
Time Indication: 0
Date: 2000.00.00
Time: 14:14:25
Freeze Frame:
RPM: 1260 /min
Speed: 2.0 km/h
Load: 52.5 %
Voltage: 14.29 V
Bin. Bits: 00101100
Idle Stabilization: 0.0°KW
(no units): 48.0
Readiness: 0 0 0 0 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1203
Coding: 0000246
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283007F3F04050FC0084FD6907C00
Part No: 1Z0 951 171 A
Component: NeigungsSensor 009 5003
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: Innenraumueberw.009 5003
3 Faults Found:
00323 - Vehicle Inclination Sensor (G384)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 2
Reset counter: 53
Mileage: 147038 km
Time Indication: 0
Date: 2000.00.00
Time: 13:19:11
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 160732 km
Time Indication: 0
Date: 2000.00.00
Time: 21:13:16
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 93
Mileage: 160732 km
Time Indication: 0
Date: 2000.00.00
Time: 21:13:16
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0040
Revision: 00019000 Serial number: SKZ7Z3G0113667
Coding: 0000400
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
