1.8 20v » 2013/Mar/19, 23:30
VAG-COM Version: Release 311.2-N
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 8D0 907 558 S
Component: 1,8L R4/5V MOTR HS D01
Coding: 04001
Shop #: WSC 05314
2 Faults Found:
16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit Malfunction
P0135 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 919 910 P
Component: B5-KOMBIINSTR. VDO V34
Coding: 04442
Shop #: WSC 00222
IMMO-IDENTNR: VWZ7Z0W0618410
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 F
Component: 0B Zentral-SG Komf.0002
Coding: 00257
Shop #: WSC 05311
End -------------------------------------------------------
Cik noprotu, kautkas ar zondi nav kārtībā ! Mainīt zondi vajag ?
