VWmotion.lv • Apskatīt tēmu - DEBUG MODE
Problēmas foruma darbībā
DEBUG MODE
Atbildēt Fancy » 2009/Jūn/27, 1:16
ould not connect to smtp host : 10060 : A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
DEBUG MODE
Line : 112
File : smtp.php
Fancy
Atbildes: 5223
Atrašanās vieta: Mārupe
Braucu ar: tavu draudzeni
Atbildēt Lūsis » 2009/Okt/21, 18:02
Nevar pievienot avatara bildi no weba:
Unable to upload file
DEBUG MODE
Line : 251
File : usercp_avatar.php
Lūsis
Atbildes: 147
Pievienojies: 2009/Jan/02, 15:47
Braucu ar: 17. trolejbusu
Atbildēt Sayed » 2009/Dec/08, 0:18
Ajms nu pat atsūtīja:
man sodien dazzas PM naak ar sitaadu Fignnu
Could not update private message read status for user
DEBUG MODE
SQL Error : 1264 Out of range value for column 'user_unread_privmsg' at row 1
UPDATE phpbb_users SET user_unread_privmsg = user_unread_privmsg - 1 WHERE user_id = 99
Line : 273
File : privmsg.php
Sayed
Atbildes: 912
Pievienojies: 2004/Feb/26, 5:46
Braucu ar: Ar Prātu
Atbildēt Jazzer » 2010/Jan/20, 15:24
Kur ta forums bija pazudis? :roll:
Jazzer
Atbildes: 3366
Pievienojies: 2004/Mai/10, 19:52
Atrašanās vieta: Riga, Purvciems
Braucu ar: :D
Dzinējs: Ir
Atbildēt shl » 2010/Jan/20, 16:19
Jazzer rakstīja:Kur ta forums bija pazudis? :roll:
Jāa man arī tikai tikko izdevās pieslēgties.. Visu rītu un dienu DEBUG'u rādija.. :)
shl
Atbildes: 323
Pievienojies: 2007/Jūl/30, 21:49
Braucu ar: Passat
Dzinējs: AVF
Atbildēt Xplod » 2010/Jan/20, 17:24
ar atgriešanos :worthy: :mrgreen:
Atbildēt Fancy » 2010/Feb/09, 0:32
Ran into problems sending Mail. Response: 535 Authentication failed. Restarting authentication process.
DEBUG MODE
Line : 132
File : smtp.php
Fancy
Atbildes: 5223
Atbildēt GinC » 2010/Feb/09, 1:26
+1 taspats.
GinC
Atbildes: 2203
Atbildēt MārtiņšX » 2010/Feb/09, 3:20
DEBUG MODE
Line : 132
File : smtp.php
PM nevar aizsuutiit...
Atbildēt Mudvayne » 2010/Mar/04, 17:22
DEBUG MODE
SQL Error : 1194 Table 'u2' is marked as crashed and should be repaired
SELECT t.*, u.username, u.user_id, u2.username as user2, u2.user_id as id2, p.post_username, p2.post_username AS post_username2, p2.post_time FROM phpbb_topics t, phpbb_users u, phpbb_posts p, phpbb_posts p2, phpbb_users u2 WHERE t.forum_id = 15 AND t.topic_poster = u.user_id AND p.post_id = t.topic_first_post_id AND p2.post_id = t.topic_last_post_id AND u2.user_id = p2.poster_id AND t.topic_type <> 2 ORDER BY t.topic_type DESC, t.topic_last_post_id DESC LIMIT 0, 50
Line : 327
File : viewforum.php
Mudvayne
Atbildes: 3855
Atrašanās vieta: SDM
Braucu ar: auto emoción
Atbildēt envy » 2010/Mar/04, 18:10
nav jau kas paskatās :?
Atbildēt Fancy » 2010/Mar/04, 19:03
Could not obtain post/user information.
DEBUG MODE
SQL Error : 1194 Table 'u' is marked as crashed and should be repaired
SELECT u.username, u.user_id, u.user_posts, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_skype, u.user_regdate, u.user_session_time, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, u.user_allow_viewonline, u.user_session_time, p.*, pt.post_text, pt.post_subject, pt.bbcode_uid FROM phpbb_posts p, phpbb_users u, phpbb_posts_text pt WHERE p.topic_id = 14900 AND pt.post_id = p.post_id AND u.user_id = p.poster_id ORDER BY p.post_time ASC LIMIT 975, 15
Line : 399
File : viewtopic.php
Fancy
Atbildes: 5223
Atbildēt MarisX » 2010/Mar/04, 19:04
Fancy rakstīja:Could not obtain post/user information.
DEBUG MODE
Line : 399
Could not obtain search results
DEBUG MODE
SELECT t.*, f.forum_id, f.forum_name, u.username, u.user_id, u2.username as user2, u2.user_id as id2, p.post_username, p2.post_username AS post_username2, p2.post_time FROM phpbb_topics t, phpbb_forums f, phpbb_users u, phpbb_posts p, phpbb_posts p2, phpbb_users u2 WHERE t.topic_id IN (42, 54, 100, 104, 106, 164, 175, 304, 676, 877, 909, 2476, 2481, 3155, 3940, 4503, 4896, 5870, 6360, 6415, 6459, 6534, 6536, 6542, 6606, 7256, 7322, 7377, 7941, 8006, 8808, 9727, 9809, 9921, 9956, 10014, 10115, 10213, 10246, 10273, 10361, 10391, 10394, 10404, 10405, 10408, 10416, 10441, 10444, 10457, 10460, 10475, 10488, 10492, 10527, 10597, 10674, 10699, 10713, 10726, 10728, 10792, 10818, 10867, 10889, 10892, 10897, 10914, 10926, 10986, 11007, 11027, 11033, 11043, 11095, 11132, 11135, 11218, 11228, 11247, 11260, 11277, 11305, 11382, 11468, 11484, 11511, 11554, 11574, 11577, 11627, 11652, 11677, 11713, 11731, 11732, 11760, 11774, 11821, 11841, 11931, 12067, 12077, 12083, 12164, 12168, 12225, 12227, 12303, 12308, 12414, 12429, 12548, 12558, 12592, 12651, 12681, 12696, 12808, 12863, 12911, 12923, 13041, 13076, 13108, 13176, 13221, 13302, 13325, 13342, 13397, 13409, 13421, 13676, 13732, 13771, 13785, 13795, 13863, 13865, 13918, 14064, 14117, 14124, 14133, 14217, 14222, 14361, 14372, 14505, 14551, 14567, 14756, 14874, 14897, 14997, 15007, 15010, 15216, 15262, 15333, 15354, 15366, 15504, 15719, 15809) AND t.topic_poster = u.user_id AND f.forum_id = t.forum_id AND p.post_id = t.topic_first_post_id AND p2.post_id = t.topic_last_post_id AND u2.user_id = p2.poster_id ORDER BY p2.post_time DESC LIMIT 0, 50
Line : 787
File : search.php
VW passat B5 1.8i
VW Lupo 1.4 16v
VW Golf mk4TDI
VW Passat B6 2.0TDI
VW Transporter T5 2.5TDI
MarisX
Atbildes: 920
Braucu ar: T5
Dzinējs: VW T5 2,5 TDI R5
Atbildēt Fancy » 2010/Mar/04, 21:32
Kas ir jāpiespamo, lai forums atkal ietu?
Fancy
Atbildes: 5223
Atbildēt envy » 2010/Mar/04, 21:50
nosūtīts info adminam...
