VWmotion.lv • Apskatīt tēmu - Startēšana kad auksts motors
Problēmas, risinājumi
Atbildēt cii90 » 2019/Jūn/28, 11:45
Kad augsts motors, startējot ir jocīga/bubinoša skaņa. Uzreiz noslāpējot un startējot vēlreiz viss ir kārtībā. Atradu ka tā ir normāla parādība un ir saistīta ar kaut kādu izmešu samazināšu startēšanās brīdī. Atradu arī ārzemju forumos vairākus rakstus, kur aprakstīta šī problēma un ka tas ir normāli.
Cold start poor running for 30 seconds or so, making a burbling/popping noise from the exhaust and somewhat rough running (can feel shimmers in the cabin):
Caused by ECU software glitch during pre-cat heating on a cold start. This rough running only occurs on a cold start where the coolant temperature is approximately between 19c and 32c...your dash air temp will closely follow this on a full cold start so can be used as a rough guide of when it will happen. The engine will misfire for 30 seconds during startup under these conditions, making the exhaust pop, burble and rattle with the engine sound rough. It can also occur if you have done a run and let the engine cool down to the point its again in this temperature range and then you restart. There is no solution to this at present as its a fueling issue cause by the ECU, and latest ECU firmware doesn't fix it...as a temp fix if you hear it running rough like this, stop engine and restart - it won't do it again as it won't do the precat heating if the engine has very recently been started.
https://www.volkswagenforum.co.uk/showthread.php?t=22355&goto=nextoldest
Vakar notestēju, kad āra temperatūra bija zem 19 grādiem un viss palaidās bez problēmām.
Gribēju noskaidrot vai var atslēgt/pieregulēt šo ECU iestatījumu? Vai varbūt ir kāds cits risinājums šim?
cii90
Pievienojies: 2019/Jūn/18, 12:13
Braucu ar: Golf 6
Dzinējs: 1.4 TSI
Atgriezties uz Elektronika
