VWmotion.lv • Apskatīt tēmu - Divmasu spararats - atbildes uz jautājumiem
Atbildēt Storms » 2008/Aug/13, 1:34
MārtiņšX rakstīja:E ku smuks 3D demo, kaa tas meesls uzbuuveets:
http://www.youtube.com/watch?v=YnaXB8q3uzQ
Shitaads ir beigts:
http://www.youtube.com/watch?v=bFnLMQNKKH8&NR=1
Un labs:
http://www.youtube.com/watch?v=kIg3S_n5F4E&NR=1
Patenteets arii shamais ir:
http://www.freepatentsonline.com/EP1046834.html
Taa teikt izgliitojoshie materiaali 8)
Jautājums: Gribu noņemt apskatīties kas lācītim vēderā. Viņš ir remontējams vai nav, jāliek jaunu vai ir jēga lietotu meklēt, cik sapratu labā cenā esot.
Atbilde: Nav jaucams un labojams.
Jautājums: Kādi ir replace komplekti???
Atbilde: Priekš VW Valeo ražo:
New range of 4-part kits with rigid flywheel
>> Description
The 4-part Kit with rigid flywheel is a replacement product for the Dual Mass Flywheel, specifically developed by Valeo for the aftermarket.
The Dual Mass Flywheel aftermarket is an emerging market, resulting from developments in Original Equipment over the past few years. This new technology has led to an increase in the cost of the clutch function, which translates as a considerable increase in clutch repair cost when it becomes necessary. Valeo has developed the concept of the 4-part kit, enabling a considerable reduction in this extra cost, by proposing a more economical alternative.
>> Features
 In the 4-part kit, made of a rigid flywheel and a traditional 3-part kit, the vibration & noise filtering function, normally performed by the Dual Mass Flywheel, is transferred to the WX disc, which thanks to its long travel damper, has a high filtering capacity while transferring a high engine torque.
 This new technical solution from Valeo therefore replaces the Dual Mass Flywheel and the original clutch kit, when a full system replacement is required.
>> Benefits
 The 4-part kit with rigid flywheel enables cost savings of up to 30% on the part price, a real advantage for a product intended for vehicles that are already less than new.
 For some vehicle applications, the 4-part kit also increases the lifetime of the part, by
increasing the friction surface.
>> Applications
 Following the resounding success of the first kit launched in 2004, Valeo is extending the range with two new part numbers to fit popular vehicles.
 More generally, Valeo has launched a development program on this product range, and in the coming months will introduce regular range extensions, in order to cover a considerable number of vehicles originally fitted with Dual Mass Flywheels.
SACHS, SACHS Performance, Boge un Lemforder apvienotais katalogs: http://webcat.zf-trading.com/
Storms
Atbildes: 12858
Braucu ar: VW Passat B3
Dzinējs: 2E
Atbildēt alnis » 2009/Feb/05, 16:02
Taadu Valeo maiņas komplektu ar parsto spararatu esmu uzlicis savam Mk4:
+ komplekts sajūgs+spararats maksaa krietni lētāk nekā pliks divmasu spararats
+ garantija, ka spararatu vairs nenaaksies mainiit nekad, kas nav mazsvariigi 8)
- vieniiigais miinuss - laizhot sajuugu valjaa vairaak juutaas briidis, kad savienojas spararats ar sajuugu....
alnis
Atbildes: 33
Pievienojies: 2008/Nov/11, 20:31
Atbildēt evelyn » 2009/Feb/05, 17:58
Mmmm... īstenībā ļoti interesanti.... 16vLietotājs tomēr gribējā zāģēt uz puseem un apskatīties kas lācītim vēderā... Ir vēl vēlme?
Manējais dm spararats ir metams un zinātnes attīstības nolūkos dabonams :D
evelyn
Lady
Atbildes: 590
Pievienojies: 2007/Aug/03, 13:32
Atbildēt MārtiņšX » 2009/Feb/05, 18:23
Sievieshiem ar taadi ir? Es biju maniijis tikai motoriem :lol: :lol: :lol: :lol:
Sorry, iereekt jau ar kaadreiz vajag... No ko ta tur iekshaa ieraudziis? Samociitas atsperes un viss... Naff veerts fleksha ripas teereet, lai savaam aciim to meeslu izkjidotu apskatiitos...
Man kautkur laukos viens izkjidots kaadreiz meetaajas, varu atvest apskatiishanai, ja nebuushu jau atdevis luuzhnjos (preciizi neatceros)...
Atbildēt evelyn » 2009/Feb/05, 18:28
:lol: :lol: :lol: :lol: :lol:
assssprātis... :D
Nu tieši manas domas, kad dabū noskatīties to video no youtube nafik nevajag rokas ķēpāt....
evelyn
Lady
Atbildes: 590
Atbildēt imants » 2009/Feb/05, 18:36
Golfam oriģinālais bija Sachs komplekts un nevis Valeo :roll:
imants
Atbildes: 1013
Braucu ar: Audi A6 Avant
Dzinējs: Turbodīzels
Atbildēt MārtiņšX » 2009/Feb/05, 18:49
Tajaa Youtrubaa veel jauni klipinji par DMF teemu ir paraadiijushies, man domaat, ka tur jau pietiekoshi var ieraudziit :wink:
Atbildēt MārtiņšX » 2009/Feb/05, 18:51
imants rakstīja:Golfam oriģinālais bija Sachs komplekts un nevis Valeo :roll:
Valeo piedaavaa gatavu aizvietotaajkomplektu bez DMF, ko likt origjinaalaa DMF vietaa. SACHS katalogaa taadu neesmu atradis (varbuut tagad ir, neesmu skatiijies, pirms ~gada tochna nebija)...
Atbildēt 16vLietotājs » 2009/Feb/05, 19:21
evelyn rakstīja:Mmmm... īstenībā ļoti interesanti.... 16vLietotājs tomēr gribējā zāģēt uz puseem un apskatīties kas lācītim vēderā... Ir vēl vēlme?
Ne jau zāģēt :D :D Salīdzināt viņu ar savu 1.8T spararatu, lai zinātu vai arī dīzelim var uzlikt tādu kombinaciju kā es uzliku savam auto.Man interesē dažādi diametri, biezumi, skrūvju daudzumi........tādas lietas.
Atzāģējies es viņus jau darbā esmu līdz nelabumam :lol:
Tur ir divi konstrukciju varianti: Tādi kā Youtube klipiņos ar atsperēm un ir ar sešiem maziem amortizatoriņiem arī iekšā (tas gan vairāk franču mašīnam raksturīgi)
16vLietotājs
Atbildes: 1364
Braucu ar: KTM & HDi
Dzinējs: ir ekonomisks :D
Atbildēt ArmandsS » 2009/Feb/05, 19:26
16vLietotājs rakstīja:
ne PD TDI var ,bet ar 1z spararatu ,vakar aizbrauca
ArmandsS
Atbildes: 4197
Atrašanās vieta: ventspils
Dzinējs: 7a-fe@4m40
Atbildēt yanis » 2009/Feb/06, 3:35
nja sak paradities tadi aizdomigi simptomi...
kamer auksts motors ... sajugs atlaishanas galaa medz sakerties ar tadu maigu noraustishanos/vibraciju,
divmasu spararats vainigs :?:
ir ari tas gluks ka atpakalgaita liekot bik keraas dazreiz.. taa itkaa netraapa..
ja nu tiesham sanak to briesmoni mainit.. handleris shitadus ciparus met:
Divmasnieks:
03G 105 266AD "Sachs" 240mm - 363.87 Ls
03G 105 266AF "Luk" 240mm - 199.54 Ls
sajuugi:
03G141015L 204.86 240mm sachs
03G141015Lx 155.86 240mm sachs
022141015S 204.86 240mm LUK
022141015SX 155.86 240mm LUK
kautkas ar tam sajugu cenaam nav....
Tas LUK ir lietojams vai drizak nekas labs?
yanis
Atbildes: 365
Pievienojies: 2007/Nov/10, 15:27
Atrašanās vieta: Riga, Liepaja
Braucu ar: optimismu
Dzinējs: 2.0 TDi BKP
Atbildēt cakijs » 2009/Apr/27, 8:32
alnis rakstīja:Taadu Valeo maiņas komplektu ar parsto spararatu esmu uzlicis savam Mk4:
Kura vieta ALNIS tu sev dabuji to mainas komplektu, man dzinejs 1z. Laiks mainit.
Varbut kads cits zin
cakijs
Atbildes: 40
Pievienojies: 2008/Dec/22, 15:19
Atbildēt cakijs » 2009/Apr/27, 20:20
cakijs rakstīja:
Kura vieta ALNIS tu sev dabuji to mainas komplektu, . Laiks mainit.
cakijs
Atbildes: 40
Atbildēt cypress » 2009/Apr/28, 12:50
kādas ir galvenās pazīmes, ka tas divmasu rats ir jāmaina?
cypress
Atbildes: 279
Pievienojies: 2009/Jan/08, 13:15
Atbildēt 16vLietotājs » 2009/Apr/28, 19:19
Grab.Veicot darbības ar sajūgu (izspiežam pedāli vai laižam vaļā) auto raustās.
Pēdējā fāze-sajūgs pazūd vispār t.i. pedālis ir normāls, bet sajūga vairs nav.
Vispār no tehniska viedokļa šausmīgi viltīgs un, manuprāt, pilnīgi nevajadzīgs izgudrojums.
Pēdējais teikums ir :offt:
16vLietotājs
Atbildes: 1364
